3d slice mode for galvo fiber
Galvo version 1.6.03 In 3d slice mode, enabling clean entire image button on clean up pass seems to reverse the engrave and clean up pass. Clean up pass runs first, with the number of passes set in the engrave tab, and then run one pass of the engrave parameter, then back to clean up. Instead of running engrave first with number of passes set, then clean up
I have similar problem. Number of clean passes is random, crosshatch dosnt work. and if you are rotate 3d image, clean passes marks on incorrect position
