I would like to use the 3D sliced function in LightBurn with my LaserPecker 4, but as stated here 3d Sliced function not found it is only available for galvo lasers. The LaserPecker 4 is a galvo laser.
Is there a way to be able to enable 3D sliced option?
The LaserPecker 4 is capable of cutting through aluminum soda can with the 2W pulsed 1064nm laser. With 25 passes it can cut through 0.1mm of aluminium. So it should also be able to engrave 3D sliced images. As it is a galvo laser, with both diode 450nm and 1064nm it would be nice to be able to at least try the 3D slice feature in LightBurn. I think more and more hybrid galvo lasers will come to the market with even stronger 1064nm lasers. So eventually more people will ask for it.
To implement the already existing 3D slice feature to other lasers than just fiber, wouldnāt be that hard, would it?
Thatās part of the issue⦠I donāt know how the 3dslice function works in concert with the rest of Lightburn.
In the link I posted, Oz advised that fiber lasers work differently, the purpose of the 3dslice option.
As far as I know, being a galvo has nothing to do with it⦠itās the lasersā source⦠Donāt get sidetracked because itās a galvo⦠Co2 galvo lasers canāt make use of it either. The way the laser is moved is irrelevant to why/how the 3dslice function was implemented. It should work on a gantry fiber laser⦠where there is no galvo. The only thing the laserpecker has in common with a fiber is the lasers operating frequency.
I think Lightburn would have to answer your question. You have far passed my knowledge of the innards of Lightburn⦠even I may have made assumptionsā¦
Maybe @JohnJohn can give you a more satisfying explanation of why itās not there for the laserpeckerā¦
I understand your argument, from the actual operating at that frequency⦠so Iām curious if there is more involvedā¦
Sorry about that⦠itās in the galvo beta section⦠Iāve copied his postā¦
Diodes have extremely good power linearity, and youāre generally just engraving wood or plastic, so use āGrayscaleā mode - thatās what itās for.
Grayscale mode does not work well for deep, consistent metal removal for galvos, so 3D slice was added for those machines. It was not āremovedā for diodes and CO2 systems, as they already have the grayscale mode to accomplish this.
