Hi All!
I’m just getting started with lasers and I’m trying to set my expectations correctly.
I’ve created a test pattern from 800-2000mm/Min at power settings from 10-100% to test cutting and engraving on different materials. All seem to go well, and I’ve gotten results that are in line with my expectations. I then went to cut out 3mm birch plywood only to find that I couldn’t get through the material. I slowed the cuts down to 60mm a minute, and have had to go to 45 passes to get the material to cut.
Am I missing something? What kinds of speeds should I expect with a 5.5w laser and 3mm plywood?
Also, does anyone have a library of materials that they would be willing to share?
Thanks!
