I just received the below machine.
It comes with it is own software RDWorks.And board number RDC6442S-B(EC)
I am wondering if my lightburn application is compatible with this device please.
Yes, LightBurn will work with that machine.
I have added it manually but it says communication error.
Please guide me
Did you install and run RDWorks, they provide a required driver? There is also the opportunity to install the driver at the end of the LightBurn install. Did you install that?
Yes I have install all required drivers.
I checked the device manager after connecting the two USB cables and everything fine.
I did not find anything under COM. I only found two UBS convertor.
Also, there is an Ethernet cable.
Please guide me how to add it to LightBurn
Have a look at this and let us know where it is failing or does not work for you:
https://lightburnsoftware.github.io/NewDocs/AddingYourLaser.html
