I ‘comfortably’ run mine at 18ma for high power. As far as I know it’s common practice to use at least a 30ma meter. So it probably was ‘pegged’ or close to it at 80% power.
What you are facing is what we all face and that is a configuration issue.
In theory there should be no difference. Generally what it does it reset everything back to default, which is back to a configuration issue.
Might want to try this and we’ll see where we go…
Ensure you’ve gone through the setup for your Ruida and the ‘Edit → Device Settings’.
You should read through this as it will come up.
So at this point what exactly are we solving?
We’ll get a handle on it… ![]()
