How To Ask For Help
Folks,
When asking for support for LightBurn via this forum, email or anywhere else, please keep the following tips in mind for the fastest and most helpful answers.
Please provide these details:
  • What machine do you have?
  • What controller does it have , and what firmware it is running?
  • Are you running the latest version of LightBurn?
  • Is the issue new, or has it happened before? What kind of computer is it, and what Operating System is it running?
Please note these things:
  • Please speak in complete sentences with proper spelling, grammar and punctuation. Fragments and run-ons are not pleasant nor easy to read.
  • We understand that many of our users are not native English speakers, and are more than accommodating, but some effort should be made from everyone please.
  • Explain what is happening. A picture tells a thousand words, but we need at least a few words explaining the context: what did you do, what the issue is, what the machine is or is not doing, and so on. Also please include pictures of the full screen, and then use words to tell us where to focus our attention, as described above.
Spell it out for us: "I did ___ , I expected ___ to happen, but instead ____ did / did not happen.
tl;dr: pictures, details, and punctuation, thank you.
Not sure how to screenshot? Click here for instructions
Just a few steps to make the lives of the people helping easier, and to improve the odds of getting valuable responses and assistance in finding a solution.
Thank you!
Additional information can be found in our documentation under ā€˜How to Ask for Help’.
Origin problems
Need help with lightburn
First time setup and cannot get the wizard to find my laser
LIGHTBURN issues an error in orders $ 30 $ 31 $ 32
Lightburn seems to always run my cuts as 2 passes, no matter what I specify in the "Passes" field
Laser isn't adjusting to power changes
Lightburn does not work
New to the program and having issues
Won't connect to laptop new universal 15000
New laser owner! I have to type $X to unlock every time I open and close the door?
Factory setting
About the Shapeoko category
Head moves but laser doesnt fire
Unexplained Z movement
Lightburn not powering laser correctly
Help new to light burn
New User and laser signal is off, worked yesterday, what do I do?
Mac Not seeing laser
Having trouble engraving images
Help, license issues
Software crashes
Burning Photos of a person
I need help please
New user lightburn not responding help!
Laser dont cut through
Weird shapes in circles and letters
I need help in drawing line with my 60w machine
Power scaling not working and staying consistent no matter the power output
Mac keeps losing connection
Mini GRBL 2 big problems
Laser to Software
Lasermaster will not burn
Newbie Image burning problem
Burner is only completing top half of wording
3018 laser is fine in lasergrbl, but nothing in lightburn
Problemi con la videocamera
Can’t get laser to burn anything
Image is shifting as its engraving
Laser lights up but won't engrave or cut, help please
K40 max speed for raster engrave
Incisione laser lightburn
Calibrations within in the burn area
Ortur says busy and will not work
Error 22 . This is so frustrating
Help i can not get anything to work
Stops during burn
Laser won’t connect
Laser wants to move but not fire
Laser fade out and got wider when printing
Laser power setting
How do I get started burning/
Does lightburn have a debug or fault logging option. Strange failure in my cut pattern
Help need to figure this out
New to laser engraving with one problem
Upside down and backwards
How to get proper settings for photos
Need help burning a photo
Lightburn will not operate ORTUR 2
Light brun program stuck
PLEASE HELP! Need help with G-code
Burning grid to base board?
Image sizing problems
No Laser Burn using lightburn
Etching Speed Help Needed
Lightburn on an Openbuilds Acro 1010
Missing part of text
Lockups on v0.9.22
Laser works, but won't burn?
Best settings of Lightburn on NEJE master 2s MAX
Laser connected and working but not engraving
Laser stop in middle
Hello fire button doesnt work
My score lines do not transfer to my laser
Lots of issues today... HELP!
Image chopped or not full image
Light burn mirror image problem
Yorahome 6550 40w
Finds origin but laser won't run properly
Laser skipping part of my design
Bad, not good vibrations
Cant seem to be able to set origin
Connection issue's
Why has the grid size suddenly changed?
File information
Graveur laser totemS
Lazer shutting off mid burn and not completing burn accurately
My images are backwards
Troubles adding my ruida laser to LightBurn
NEJE Master 2S Max stops in middle of project
New laser setup troubleshooting
Power settings don't work properly. Used to but all of the sudden BOOM!@#$#@!
No acces in port com
NEJE Master 2S Max 30w - No Power using Lightburn
First photo with 15w universal
Can you unload lightburn from your computer and reinstall the program?
Having issues after installing newest version 1.0.01
Foxalien 4040-ex
Classes to learn Lightburn with 40w Falcon2?
Error:15 Jog target exceeds machine travel. Command ignored
Light burn neje 2 axis problem motor noise
Engraving just stops
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the 'Devices' button to reset the connection)
Not enough extend space mid job
50w Co2 stopped cutting but continues around
Help with wiring
50w laser running at different power level then lightburn
new with a laser
Shapes within Shapes cutting
Grayscale image issues
Two treesĀ® totem s 40w
Cut shape mine is not highlighted so I can select it
Can't regain focus
Transfer failed lighburn 1.1.03
Enlarging my Ortur workspace
Transferring image to laser
xTool D1 - same problem?
Frame and home not working ruida 6332m
Locked Up Camera
Problema con la connessione (Problem with the connection)
Unable to imoport files to Light Burn
How do I download images into library that are compatible with girl and light burn?
Lightburn says it is busy cannot get it off
Not firing after purchasing software
AtomStack A5 not burning
Lightburn won't connect to AtomStack Laser
I am getting issue in engraving. Font are not properly getting engraved and sometimes it’s doubling font
Enrgaving alignment problem (Lost Motion)
Lightburn..Not Responding
Frame does not complete
NEJE Master 2 does not connect to my Lightburn program
Software won’t recognize my laser
Laser stops and won't restart
Problems with burn order after updating - Sculpfun
Main grid will not more to both zero's
Endurance laser 10 w
I get a transfer or there’s a problem sending data to the laser and it says the machine may be busy or pause
Software needs updating
Laser burn between letters
30 day Free trial, pops up in error
Will Turn On, But Will Not Burn
Anybody have the AtomStack p7 and can help me I’m having a really hard time
1mm lost pls help me!
Error message trying to install latest update, how do I fix?
Elongated Circles
Laser position Not working with new Update
AtomStack Pro 7 prints are coming out skewed?
Device not recognised
LightBurn problems after upgrade
New to forum need some help
Trouble with Laser 20w
Atomstack P7 M40
I cannot get the fire button to work on my jtech kaser
Sending files to AWC608 doesn't work anymore
Laser stops 1/3 or 1/2 way for no reason
Connection Problems after update
Laser move not , onlu moves up and down
I got a key . but its not working
Error 3 - Ortur Laser Master 2
Rotary set up with logo
My laser won't burn
Laser qui ne se coupe pas entre les forme et se met en toute puissance Ć  la fin de sa coupe
Just paid to upgrade from expired trial to subscriptiom
Risco de queimado feito pelo laser quando em deslocamento pela peƧa a ser impressa (Burn hazard caused by the laser when moving through the part to be printed)
Renew updates to licence
File "Out Of Bounds"
Does ligghtburn work with Mac OS 10.13.1?
Xtool D1 Locking up when framing
Laser head not moving to home position
I need help to use correctly my machine
Can't draw a circle with stool
Is this a good place for support?
How to fix unrecognized USB and Alarm Lock issues
Laser does not complete burn
I need help setting
Getting started from a newbie
What is VDD low, try restart
I cannot get my lightburn program to access files on my computer In order to complete setup
Characters become white. Please tell me what to do.
Misalainment of output
Laser picture comes out smeared
Homing cycle not enabled direction feature not working
Sculpfuns9 is etching wave lines should be straight
Can my trial be extended>
Atomstack x7 pro loss lƔser intensidy
All my circles ant coming out round they are coming out like a ovel when it engraves
Machine does not move or home,lost origin
Sculpfun s9 laser issues
Endurance 10 Watt+* laser
Turning off optimize question
My xtool only moved up and down
Sculpfun S9 Machine paused or Busy
Library settings have disappeared
Not saving into library
Rahmen falsch - Wenige CM daneben
Getting started with XTool and Light Burn
Cannot see the laser beam
xTool D1 - Another communication obstacle
Font Aerial come out ziggy zaggy Slow the y and x axis down. I have a new ortur pro 2
Job quits before completion (k40 ,cohesion3d laserboard,smoothieware)
Cutting Lines Begin&End to thick
USB port Already in use
Senden von Daten
Hi friends help me please
Comgrow Laser Only Able To Make Squares
Help with Co2 tube
Lightburn will not recognize my XTool D1 10W engraver
Lightburn bridge hit and miss
Light burn and RUIDA not syncing on the speed
Creating a Poll for the Reading of the LightBurn Documentation
Why is my library not here- where are the presets?
Materal Test Speed settings
Smartcarve ratio parameters in Lightburn
Help! Laser lights and turns on, moves but doesnt burn. Please help!
Very poor cam in my opinion
Twotrees laser stops firing
Laser firing both during move and cut operations
FRAME SLOP :Using Rotary, hit: start Get: FRAME SLOP< WORK PAUSED
What is markparam.lib?
New User - Error 9
Engraver couldnt engrave the correct image
Losing Connection with xTool
Having problems with home limits
NEJE Master 2s Max Stopping in Lightburn
I just burned my floor lol
Unanle to start engraving / cutting job
Laser comes on immediately when power is connected
Crashing after update
Help needed with lightburn and xtool d1 will contribute to foster beer fund
Making Scanimation with LB
Как Ń€ŠµŃˆŠøŃ‚ŃŒ ŠæŃ€Š¾Š±Š»ŠµŠ¼Ńƒ - (How to solve a problem?)
Corte Maior que o Projeto no LightBurn
Monport K40 will not burn line unless Constant Power on
Aspect ratio is wide and short on print
Omtech help polar350
Second Laptop w/Lightburn does not work
While trying to solve a problem with my laser, another problem occurred, help
Connecting to Mira 9
not work BOOT(UART0/UART1/SDIO_REI_REO_V2))
LightBurn Forum New User Guide
Max axis travel problem
K40 new ā€œomtech board upgrade (smoothie)ā€
Yorahome 6550 40 watt using pc running out of bounds no limit switches + jog buttons backwards
Circle in lightburn code is more like a rectangled ellipse
Lightburn not responding\crashh
Camera calibration help
Can’t get my laser to fire
Why doesn't lightburn recognize my laser
The cnc machine on GBRL CO2 slowly engraves. How to speed it up?
Laser uneven image
Need Help - Provide Information
how to assign a negative layer and positive layer in same image
Struggling to Engrave Yeti
Lazer on all the time
Latest version has killed my lightburn installation
Lightburn performance declining
El lƔser graba doble lƭnea
Ruida fire always on after start cut
Laser malfunctioning
ALARM:1 Hard limit triggered with limit switches
Hard limit triggers
Monport GM Galvo stays in ā€œframingā€ and is never ready
Stops framing and engraving in the middle
LightBurn v2.0.00-RC2 Release Candidate
Help with stepping and sizing value
Issue with UV 5W Laser – ā€œUnrecognized Board Signatureā€ & Stuck in Framing Mode
About the Creality category
About the Tips & Tricks category
About the MillMage Software Questions category
About the FluidNC category
About the grblHAL category
Looking to connect my Snapmaker Ray using a 2W IR Module and can't seem to find any info?
About the MillMage Hardware Compatibility category
About the grbl category
He comprado la actualización core a lightburn Pro
About the Duet category
About the Mach3/Mach4 category
About the Onefinity category
Laser shuts off in the middle of project
Origin position problem
About the grbl-STM32 category
Longer Nano laser burning only one radius on a box
Text printing Backwards
About the Genmitsu 3018 category
About the X-Carve category
About the MakerMade category
Laser allignment
About the LinuxCNC category
Pas de connexion machine
Having trouble with homing
Laser wont fire but will move
Lightburn does not frame completely. Stops about mid ways. Never comes back to the start position
Mi sculpfun no corta sino que lanza un rayo azul que no corta
Not framing, just goes back and forth
GrblHAL 1.1f Problems with lightburn
Move buttons: the Left goes right, and the Right goes left
Laser Machine can not connect. It shows "error encountered Disconnecting... Then after a while framing like
Material Testing Generator
Help with my Longer 10w laser
LightBurn Šø AtomStack s30 pro
About the Snapmaker category
My engrave / image problem setting
LightBurn line question
atomstack p1 lasers font slanted
Dumb man need help
Cut Lines around garden tags
Hello all, I am still new to this
Mks dcl 32 parametrj
3018 Is it machine or software?
Versione 2.0 non fuziona
Forum Updates and Improvements - Fall 2025
Brulure sur les deux face a la decoupe du contreplaque de 5mm
G-Code locked out during alarm or jog state help
Imagens e fontes distorcidas
Problema con camara
Ortur Master laser 2
Please Help Us Keep the Forums Organized and Support Efficient
Setup to cut the right size
Just getting started with Eleksmaker
Problem with rotary axis
Searching for "Start Speed" setting
Origin issues not moving to position on work area, keeps cutting in same spot
Creating Material Library
Loosing position in larger cut files
Problemi incisione
We wobble when engraving small
I need help with my red-black Ruida 500x700 size laser
Photo help on tile
New Curved Text Option - Odd behavior
Messa a fuoco automatica
Suggestion for text to path tool function and "ghost" images
Small Non Cut Areas
Problem with 9.24
My program gets stuck on the Pan/Drag tool often
New user with questions - Laser not turning off between cuts
Image gets cutoff
Not cutting to scale
15W fixed laser diode, setting for cutt
Engraving photo
Laser not Burn on wood
Laser head moves incorrectly
Repeaded question
