The shapes in this file use ‘Cut Order Priority’ set in the ‘Shape Priorities’ tab, using ‘Order by Priority’ in the ‘Optimization Settings’ and these shapes have assigned variables set unusually high. Did you make these adjustments to this file?
You can see that they are set differently, as signified by the uses of ‘multi’ when everything is selected.
Thanks for the clarification. Also gave me a good exaple of what I was unclear about in the properties.
I just looked and saw the cut was set to line. Didn’t look any further. Sorry, sad help, eh?
I did notice that the preview total time went from about 4 and a half minutes to over 4 and a half hours…
I do have a question about this from the my first post.
None of the ‘dropped’ lightburn files displayed as I expected. What happened? Didn’t know how to correct it. I just ‘drag & drop’ the files, like always.
I am not fully understanding what you are after, exactly. The test files generated from Glenn’s automation provide many options for building test pattern grids for different needs.
