Some banding issues and could be darker
2 hours
Can you explain your method? I had real trouble burning to a tile…looks great by the way.
What were your settings?
1200 @ 50% power passthrough (ImageR) . Contrast could be better with a slightly heavier coat of paint as I have discovered.
Astro,
I am noticing some undulations (look at the 2 feathers pointing downwards behind its neck: both the feather and the neck line wiggle X-axis direction). Not sure the root cause is also generating the banding. But it would be worth looking at. (I’ve seen on YouTube someone having this issue, seemed a bit inconclusive on the resolution. But if I recall, he rebuilt his frame, cleaned his wheels and tensioned his belts (replacing stepper motor didn’t resolve it)).
