Does ( 8MP LightBurn Camera (4K-W) cover large machine area, my machine working area is 1300*2500 mm
Use the Camera Select Help tool to give you an idea of coverage and height requirements for the various cameras.
It’s located under Help > Camera Selection Help
You’ll need the bed size of your laser, as well as the distance from the laser bed to where the camera will be mounted - the selector will then guide you to options that will work for your laser, and link directly to them on the LightBurn web store.
Thank you All
There is no enough height inside the machine as shown in the setting, at least 62.49" is required
Swap position of X and Y values.
