Hi any idea what is going on.
with 9.20 my file is ok
same file in 9.21 as Label mirrored!!
Did you create the file with a different device origin? (did you create the file?)
i used this site Lightburn Advanced PowerScale Generator - O2 Creative
the first picture is when loaded in 9.20
second picture is the exact same file in 9.21, but text is verticaly flipped. Easy to correct , but why?BTW it is only the text that is flipped the squares are at the proper place)
Text was actually displayed incorrectly in the previous version if you loaded a file that was created with a different machine origin. The design was flipped except for the text. Now, the text is also flipped, so it is more consistent, and simpler to correct.
