I’m finally getting around to a dedicated A-Axis rotary. Everything works great for general G0 moves or when just jogging with LB but when it starts a burn it stutters. I’m doing a simple 30x30mm cross as a test to make sure I have all of my configuration right and you can see in the video that the rotation axis
line comes out as a dashed line.
LB 1.4
Cohesion 3d Mini with the June 2019 Firmware and Config
So continued rotary issues. Turning off the smoothie pause delay did address the a-axis stutter although I feel that is a band-aid over a different issue since the x-axis works fine. However now it’s not connecting A and X correctly. The images here show it’s stopping the A before it reaches the end.
I really think this may be some sort of ramping issue for the rotary configuration but I’m not sure where to look next.
Select Cut-Through and select Start
From here you’ll want to tinker with the Start pause time (ms) and End pause time (ms) with Cut Through enabled for both. This should close the gaps.
Thank you, I’ll take a look at the docs around that.
Before I do too much more I think my tube or power supply is toast. It stopped burning completely and won’t even burn a hole in tape on the first mirror even though the tube looks like it’s firing.
I’ll keep those settings in mind for when I get back up and running. I think I just had a chain of issues all hit at once.
