Hi All,
I mainly do engraving with my Chinese 100w Rudia 6040 laser however I am now thinking about using it to do some intricate cutting of 1/4" (.185" Actual) Birch plywood. I currently use a small air pump similar to the one that came with the unit. I am going to upgrade the pump for the cutting.
Can’t really comment on the pump as I don’t own one, I use a compressor what has an AC air drier unit so there is no moisure going through where the lens is.
Cutting 6mm Ply I would think you would need 80% power 20mm/s. Depending on what tube you have etc, might need to go a bit slower.
I think you would be better off with a real air compressor and at least one device to catch water. Many people recommend California compressors as they are quiet. I have a Kobalt Quiet Tech from Lowes, and it works fine- but its 2.5-gallon tank is too small so the compressor runs a lot, and the tank is steel and rusts. Look for at least a 2.5 gallon and an aluminum tank.
Hi Jack. Thanks for the info.
Boy, 40-60 psi is a lot higher than I thought I needed. I was thinking around 10-15 psi but I have never cut with my laser so I appreciate the knowledge and help.
I will definitely up the psi when cutting and lowering for my simple engraving.
I have never cut with my lasers. I have a 4x8 cnc router that I have always used for contour cutting however with the projects I want to tackle a cnc would take all day compared to the laser.
I think all the engraving I do is at low pressure. If the pressure is too high, then it could spray ‘debris’ over you material. There is probably some ‘best’ pressure…
When I cut, I don’t want anything around and high pressure leaves clean ‘un’ sooty lines.
