A cutting question Duet Acrylic
Good day folks. Hope all is well in your part of the world.
I’m attempting to create a sample hotel key ring. My line layer is blue, and fill is black. When I do a preview of the whole item, the hole at the top doesn’t look like it will be removed so I can place a key ring on it. What am I missing?
Google Link to Keyring
Thanks for any guidance..
It is not easy to judge without seeing your file, but if I have understood it correctly there are several possibilities to solve the problem.
The easiest thing is to place your cutting layer at the bottom of the hirakie, then it will cut out exactly what you want, including the “covered” keyhole. But there are other, more elegant solutions, where you optically retain a better look over your project.
I just see there’s a link to your key ring, I’ll try to look it up.
The hole for the key ring is achieved by duplicating the small hole and putting it on the same layer -C00-black.
… as I said, it is only cosmetic because the blue layer will cut the hole out, no matter if it is filled or not.
But I have allowed myself to change your file a little, so it will process faster :wink: you can try if it is something that can be used or else you set the layer back to what you want. I have not changed power or speed
Motel Key-retur.lbrn2 (73.1 KB)
Bernd, what did you change? Processing order?
The first answer was without seeing the actual keychain, and sometimes one layer overlaps the other…
So, the layer order was ok in the original.
(But generally the last layer should be the layer that will cut the outer edge.)
The hole for the ring itself is duplicated and added to the black layer to make the donut.
It should work fine. It is just hard to see the blue cut line.
that’s what I’m saying… :wink:
Or just delete the inner black circle.
I said it in less words :slight_smile:
Not expecting this to be the last word, but…
  1. Ungroup everything.
  2. Click on the black dot, then click on the blue layer.
  3. Delete the small inner blue circle.
  4. Regroup it all and make parts.
Thanks all for your input. This is the only time of the year when I have time to experiment, and come up with items for my customer down south.
My wife also educated me that no one in their 20’s or maybe 30’s will know what it is anyway… LOL Just us old geezers remember hotel keychains like this one…
I wanted to do some of this using DUET acrylic. Blue on top, with a white under coat. I don’t have enough air assist to keep the blue from melting and mixing in with the white. I have a spare air compressor in the barn I could use to introduce a higher PSI but not by a whole lot.
I’ve never really messed with acrylics, and barely use my C02 anymore. I would love it if Santa brought me a UV Fiber, but that’s not going to happen either. AND, I’ve been a good fellow most of the year… !!!
Thankx again folks.
Learned something new! I have some black on gold that I am getting ready to experiment on. I knew it was going to be difficult, but was not aware of HOW difficult. :joy:
Maybe too much power or not enough speed: the color layer is barely a skin and takes very little energy to vaporize.
Start by running the engraving as fast as the machine will go and apply barely enough power to light the tube, then work upward from there.
These test pieces are Trolase with a 60 W CO₂ laser at 400 mm/s and 14%:
This is one of the few cases where if brute force isn’t working for you, you’re using too much of it. :grin:
Appreciate it Ed… I’ll give it another go today and see what falls out.
Update: Here is the backside obviously. I’ve adjusted the power/speed 3 times for the oval marking. I’m also going to do another one without the horizontal lines intersecting with the outer oval..
Speed 600 / PWR 10. I’m using Isopropal and Mr.Clean sponge to clean. Thanks for the guidance… There may not be any interest in these at the shop at the hotel, but still worth giving it a shot.
Put everything on the same layer and engrave it in one pass to eliminate the burnthrough. This may take longer than optimizing each part of the design, but situations like this call for quality, not speed.
Thanks Ed. I did finally put the horizontal lines top/bottom & the Txt on the same layer. Still having a bit of problem with the white oval part still getting some blue residue in it. Probably not enough for a customer to care, but would really like to get the white… WHITE, not dirty white. I don’t like how dominate the horizontal lines are too. Going to make them thinner.
Motel Key.lbrn2 (73.8 KB)
I made the file so you can cut out the whole for the keyring. the red line is you cut line
Thanks Blue… I may just ditch this project. I can’t seem to get white WHITE’s. I made the horizontal lines not so dominate, and the bottom ones are dirty. I saw it as it was engraving, and knew it wouldn’t clean up. I may have to introduce air flow across the piece from the bottom upwards. BTW, I’m not using any masking on these…
I might try some on regular acrylic, and see what it looks like.
This is what it looks like just off the laser before any cleaning. I’m thinking residue is being re-introduced from the previous burns…
Moah Ahrrr! :pirate_flag:
You may need assist air on these, despite the usual recommendation to not use it for engraving.
Is this Concentric in the border line:
If so, just use ordinary Fill engraving to do the whole thing.
If not, then something is wrong, because the trench should be just barely deeper than the blue layer and pretty much flat on the bottom.
AFAICT, you are overcomplicating this. Put all the engraving on one layer, do Fill with All Shapes at once, and see what happens.
Upload the lbrn2 file so we can peer at it.
