A few GIS based projects I'm excited about
I’ve been doing a lot of work using QGIS to get map information to import into Lightburn for designing layered cuts.
More than happy to share techniques, data sources I’ve found, etc. with others. I found most of the guides I came across were challenging to follow or replicate. I’m sure I’m not the only person to encounter this. Below are a few of my ‘almost’ finished creations (and a couple in process).
Made multiple versions of these, each with different engraving. Images I engrave are usually modified versions of photos I took. For example, the sailboat in this one was from a vacation photo I took in Florida.
This was before finishing it, but made for a friend who saw a similar design online. I made it for her to give to her partner this next Valentine’s Day.
Map of where my lake house is. I also had a 2 layer version.
In process:
Maui - layers for elevation and water depth. 2 versions -
Hope you enjoyed these or got inspiration from them! You can follow my FB page at Dog Under Foot Designs - I try to post my finished projects there too. I tried to post more in this single post but I’m limited as a new forum user to 4 pictures.
– Teagan
The maps fascinate me!! I’m a total newb to the laser gig, with a few years of CNC background. Where is a good starting point for making the maps?
Wg
I used QGIS. I started with mostly raster files from NOAA and other places. Then I used the contour plug in to make the contour lines. I exported them as dxf vector layers and then brought them into Lightburn to layout and clean up.
My username @ gmail you can email me and I could send you more detail and some sample files.
Excellent, thank you very much.
Wg
