A Rotary Reminder
When I enabled my Rotary within the Rotary Setup, I SHOULD HAVE gone into the settings and TURNED OFF “Use Laser Offset” so to set the correct starting point, BUT I did not and got “bit” with the starting point offset being turned ON.. For US challenged folks, it would be nice to see the phrase “Check use Laser Offset Settings”, in the rotary setup dialog box as a notice to turn off… Just a thought.
EDIT: Link to suggestion submission
In the upper tool bar there is Feature Suggestions that will take you to a site you can put your suggestion in and the users can vote on it.
Make note in your post that you did this and supply a link for others.
