A1 error and problem with Vevor 10W laser
Hi,I am new here.
I try to install and get that error on my Vevor laser: ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
On or near line 0:
Please how can I resolve this? when i press home,its all ok.
But when i press frame or start,iz moved a little bit,rattle and stop.
I am sitting 7 hours and try to fix to not bother anyone,but i am very frustrated.
Please if ther is someone that can send me his photo settings,bcs I am new in this field.
Thank you
Home the machine and select Absolute Coords in the Laser window Start From: box. If that does not solve your problem, report back.
Thank you Mikey,but unfortunately nothing…Now,it pop up this.. ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection).I reset with the right click on devices but nothing…the laser wont move on frame or on start.
Write this on a piece of paper and tape it to your monitor:
Preview is your best friend in Lightburn.
Lightburn said you are telling your program to move farther than the physical limits of your machine.
  1. Select your project and open the Preview window.
  2. The green box is the limits of your machine.
  3. Turn on Show Traversal moves and you will see red lines and shading.
  4. Those red markings are where the laser travels as it moves through the program.
  5. If any red lines cross over that green line, you have found your problem.
If you get a small window that says “One or more shapes are crossing the edge of the machine workspace”, that is telling you the same thing. Even though your part is entirely within the machine workspace, Overscan can be what is making the laser go out of bounds.
If you have not seen this video, it is worth watching.
