Thank you, again, for the info! Well honestly, I wouldn’t really even know how to issue a G92 command or anything of the sort!
I don’t think I’m doing anything to reset it - although when testing it, before, I hit the Set Origin button with the laser at different locations. I’m completely new to all of this…but that isn’t to say that I haven’t screwed something up. I tried a few recommendations that I saw online before writing. I checked in the Edit>Device Settings>Gcode tag & both boxes are empty.
But for now, here’s the background: I tried LaserGRBL first & things seemed to work well and normal, but I didn’t care for it much, so I downloaded & installed Lightburn. All that I did was add the device, then setup a couple of cuts & engravings on a piece of cardboard…I had to use the “Current Position” setting because it was doing the strange centering behavior when I would tell it to go to the Origin.
After receiving your last message, here’s what I’ve done: (I had it unplugged from USB & from power)
- plugged the last into power & into USB (Lightburn closed)
- powered on the laser (it was at 0,0 - bottom left-hand side before powering up)
- opened Lightburn
…when opening Lightburn, it did a Homing cycle by itself & here’s what I have in the console (it bumped into the limiting strips and gave this output):
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 185]
[OLH: OLM_ESP_PRO_V1.2]
[OLM: GENERAL]
[DATE:22:44:33 - Oct 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSLW,35,4096,3]
Target buffer size found
ok
Homing
ok
- I hit the Home button & it just returned “ok” and clicked against the metal strips again
- running the instructions you gave me before now:
$I
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 185]
[OLM: GENERAL]
ok
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=0
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=43
$23=3
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=70
$262=320
$263=30
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:201.000,146.000,0.000]
[G92:201.000,146.000,0.000]
[HOME:0.000,0.000,0.000:7]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|WPos:-201.000,-146.000,0.000|A:S|H:1,7>
ok
Thank you, again, for all of the help. I will certainly hold off on making any changes or doing any cuts/engraving/etc until we figure things out. I’m in no hurry, so no problem at all, there. Whatever you need me to do, I’ll certainly do. (I’m powering off the laser & unplugging from USB & power now + closing Lightburn)
