Posting to help others as ive noticed Longer lasers have unique command codes that can be tricky to find. Error Accel Sensor Triggered.
- Check that the engraving machine is placed on a stable desktop to avoid machine shaking during movement.
- Adjust the motion sensor trigger threshold. First run the Lightburn or LaserGrbl software, connect the engraving machine to the PC using USB, and then enter and send the $40=200 and $41=40 commands in the control command console to lower the sensor trigger threshold.
- If the motion sensor is always triggered at the beginning of engraving, it may be that the sensor is damaged. You can send the “$39=0” command in the Lightburn or LaserGrblk console to turn off the motion sensor function (if you want to turn it on again, please send the command “$39=1”).
