ACMER P2 33W - LightBurn 2.0.04
Bonjour à tous
possesseur laser plus puissant, dés la mise en marche par machine, pompe à air fonctionne. déplacement Ok, mais le laser ne fonctionne pas
Merci de votre réponse
I have a more powerful laser; as soon as the machine is switched on, the air pump works. Movement is OK, but the laser itself doesn’t work.
I would review all the steps done during assembly. The air pump should not come on with the power on if it is wired into the controller board.
