Hi All,
I’ve been trying to achieve a Decent colour fill on my Acrylic Engraving, but can’t seem to get it right, Just wondering what people have found that works the best? I have done some searches and looked at old topics but can’t seem to find the answer I need…
Material Specs: Acrylic (Cast) 3mm - Engraved Shapes/Text
What I’d like to achieve:
A Colour Fill of engraved text or shapes that leaves a Glossy finish flush with the surface of the rest of the acrylic.
Already Tried:
1: Nail Polish
First thing I tried was Nail Polish, which worked surprisingly well, but I Learned the hard way that cleaning off the excess with Acetone was not a good idea as it cracks the acrylic - Lesson Learned, Should have done my research!
2: Spray Paint
Second thing I tried was spray paint - This was OK, but the paint doesn’t properly penetrate fine engravings or lines.
3: Water Based Acrylic Paint
I then bought some water based acrylic craft paint and tried to use this. I Masked the piece using application paper (Masking tape) and then engraved through. I flooded the engraving with the Acrylic paint and waited for it to dry. Unfortunately, I had slight bleed and also found that it would crack/pull out the infill… AND it must shrink as it dries as it wasn’t as flush as when applied.
I also tried Acrylic paint without using mask, by flooding it, scraping excess while wet and then cleaning the remainder with a damp cloth… This seemed to pull the paint out of the engraving. This also left a dull (Not glossy) finish to the coloured infill.
So, Has anyone found a tried & tested method to colour fill with High quality results on acrylic?
I’ve heard of Oil based enamel paints, 2 part epoxies & Colour Tint etc etc and there are also places that sell what they claim to be an acrylic colour fill paint… but I want something that is readily available and not massively overpriced.
Look forward to hearing suggestions and seeing results! Thanks in advance.
Kind Regards;
Al
 It stinks, and doesn’t cure anywhere near as fast as claimed even under a very strong UV light! Think i’m going to go back to the Acrylic Paint method, but with some decent quality Paper Application Tape & Some Gloss Acrylic Varnish on top. This time, I’ll actually post some results photos in case anyones interested… If not, well i’m just talking to myself!
 I’m going to apply a spray on seal to it today to see if this eliminates it.  I havent heard of anyone using this product before so will keep doing some test to see if i can master it as it looks pretty amazing.
