Does anyone know of a way to add a Manual Button for Auto Focus to a Rudia controller. It just seems that it would be a lot easier to push a single to focus the laser that to go through the menus all the time.
Thanks
Assuming you have Z moves turned on in LightBurn, there is a Focus button in the “MOVE” panel. Also has a hot key assigned to it that shows up if you hover over the button:
Thanks for your reply
Yes and that does work great, but if your computer is located any distance from your laser it is not as handy. I do not like to autofocus if I am not close to the laser just incase something fails. I have had to hit the estop once because the probe failed. (Bad wire in the cable)
