when adding multiple files to a library, keep getting
can you add an option to “check here to apply to all the files” vs having to select an option however many times you have to finish all your import?
You would only need to rename the file if you already have a file of the same name.
You’re talking more of a “replace all”. I’m not sure if that’s a wise action to allow our users. This way at least you are presented with the option to verify each file as you go.
heard that… understand the Pebkac delehma.
