Is it possible to add a pause function in the program at a given time to cool the laser diode while cutting? Because the laser doesn’t like overheating. The LASERGRBL program has such a function.!
123|690x338
Add a large filled object set to 0% power at a crawl.
Thank! A good idea. But adding these objects takes additional development time. It’s easier to pause at a given time.
I checked the “Your Machine” entry in your profile to see what machine you have, but this is gibberish - what is it?
I’ve updated my profile!
If time is what you’re seeking to gain, then perhaps you’re using the wrong hardware if such a machine needs resting time.
I am worried about the lifespan of a laser diode. I use the equipment for which my financial capabilities allow me!
Up for this, an autocool function (as LaserGRBL has), is a good idea
