Would it be possible to add the possibility to apply a scale factor to each copy of an object when using the array tool? For example, with scale factor = 0.9, and a circle of radius 100, the next circle would have a radius 90, then 81, then 72, etc…
Are you asking if it’s possible right now or are you asking as a feature request?
Right now this is not possible as far as I know. If you’re looking to request this feature then suggest you add this to the feature suggestion site.
