Added extension kut to x tool d1 and know I'm having a hard time running any projects
What else did you change? The extension by itself doesn’t change any of the electronics or settings on the laser so wouldn’t affect crashing situations.
I got a hold of x tool before that and let them know that lightburn wasn’t recognizing the extension kit. They recommend that I download x tool creative space and then it did recognize it.
But now when I try to run material tests it just ends up crashing.
And also the layer lines keeps blinking very rapidly and tool lines are mixed colors. The orange has black mixed with it.
I am finally able to do some projects, but not really sure if this is normal or not.
Thanks for your the quick response.
So was a firmware update completed with the creative space? This is very likely contributing to the controller crashing scenario.
This sounds very odd and wouldn’t likely have anything to do with the laser. Or I’m possibly misunderstanding.
Are you able to take a video capture of this happening? Or somehow else capture what’s happening?
For some reason not able to load a video so I’m trying with pictures again.
The outside line is supposed to be the orange tool line and it seems to be mixed with the black.
The inside is blue tool line set onoffset fill with red line set to cut on 3mm plywood
Videos can’t be posted directly. You would need to upload to an external site and link here.
This could be something in the design itself.
Can you upload the .lbrn file here to review?
It seems to do it on every file I put on it to burn.
We also mentioned about the x tool d1 software that I loaded to recognize the table size.
I didn’t have that before and was working good.
Should I delete and try to see if it changes things.
I’m not much of a computer person do a lot of this is hard for me to understand. I just know that until I extend the bed and download software from x tool it started working way differently.
Normally I wouldn’t recommend this but try uninstalling and reinstalling LightBurn. You won’t need to reconfigure the laser as long as you keep the .prefs file intact which is default behavior.
