Adding a border from downloaded SVG's
I’m trying to add a border to something I’m designing. I’ve downloaded a svg with a bunch of decorative patterns on it. Corner pieces and straight pieces. Just wanted to know if there was a way to build a frame around the workspace other than adding the frame piece by piece?
You can get a conformal outline using the Offset Shapes tool:
Offset Shapes example
If the frame is a simple circle / oval / square / rectangle, then the Draw Shapes tool is your friend:
Selecting and creating a star from the draw shapes submenu
If you need something even more complex, give us more details and somebody who’s already done that will chime in …
I figured it out using the grid array option :slight_smile:
Verily, there are many paths to the same destination …
