Hi everyone! I would like to add a small pause (G4 P.400) after each M5). Seems to give a better result for the project I’m working on. I can add it manually when I export gcode to each line in the script, but I was wondering if there was an easy way/setting somewhere to do it from within the Lightburn UI?
Currently there is no way to modify Gcode from within the LightBurn UI. The way you are doing it is the only option at this time. But you can always make a feature request at https://lightburn.fider.io/ (I think there is already a request for Gcode modification on there, you can add your vote to it.)
Cheers! Was hoping there’d be a toggle for m3/m5 with delays, but guess manual is the way for now. At least I have a script to edit it full. Voted, hopefully it’ll be added somewhere in the future!
