Adding digital air pressure readout
We are looking at options for digital air pressure indication so we can accurately repeat pressure. Looks Thunder at one point sold this, however it is no longer for sale that I can see.
Does anyone have experience adding an air pressure readout? Thinking something line the SMC ISE20:
https://ca01.smcworld.com/catalog/New-products-en/mpv/es100-114-zise20/index.html#target/page_no=9
If you don’t absolutely need a digital readout, a simple air flowmeter might be better. I added a flowmeter with my solenoid-controlled dual flow air supply along the lines of Sadler’s example:
The stock air pump in my OMTech 60 W laser produces only a few psi, so a pressure gauge doesn’t have enough resolution to accurately indicate the air flow, particularly through the low-flow engraving path.
Bonus: the little ball rattles when the high-flow solenoid opens, so I know it’s working!
It has an output to control an alarm i use it because i forget to turn the compressor on sometimes.
That is a thought. We are looking for a value to set to so we aren’t doing it by feel. thanks!
