Adding to an existing art library
Can you add to an existing Art library without having to type the title of the Art Library in again? Everytime I have to add to an existing library, iI have to drag the old onto the screen and capture it along with the new one and then type in the title name again. Is there anyway to bypass maybe just an add to existing art library button, or add to library highlighted in menu? Thanks
I can’t relate what you’re describing to anything familiar in LightBurn.
Normally you would:
  1. select the design you want to add to your library
  2. push “Import graphic from Project”
  3. title the design
This shouldn’t be a roundabout process so can’t visualize what you’re describing. Can you include screenshots of what you’re dealing with?
