Adjust an object based on the center and not corner
When I adjust an object by the top right corner handle, it adjusts to the opposite corner. I just watched a video where the guy adjusted a circle with the same top right corner handle however his circle adjusted evenly to the center. What setting does this?
Just press Ctrl when adjusting with the corner angle.
If you want to deform press Shift.
Sometimes you can use the modifier keys altogether (Alt+Ctrl+Shift) (Ctrl+Shift) .
Just try it.
or, see this ‘9 dot’ control: Numeric Edits Toolbar - LightBurn Documentation
Exactly what I was looking for. Thank you. Somewhere in the back of my mind, I remember that. Thank you for your help.
Thank you, Lou. This part I know about. It was just the manual handles I was having issues with. I hate to see someone do something different and not understand how they did it.
