Trying to use Lightburn to change an image. So Import the Jpg, size it, then right click and choose Adjust Image. It opens up and now I can make adjustments such as Jarvis or Threshold or Gamma etc. etc. etc. All good so far. Click OK and it returns to the workspace, and doesn’t save anything. I’ve figured a Klugy way around it, but why doesn’t it save the updated photo. Running Windows 11.
Image settings (Contrast, Brightness, etc.) are saved and shown on the workspace. Layer settings (like image mode) are saved to cuts/layers
Before:
Some crazy adjustments:
After:
That’s just it. When I make the “crazy adjustments” so I can see if it works, there is no change on the Image on the workspace. So in your case above, you chose Stucki, made some adjustments, and then chose Ok, and voila, there is was with your changes. In my case I do the same, press Ok, and am back to the workspace, and no changes.
Brightness, contrast, and image enhancement are shown in the workspace. Dither mode and negative are not, because they are handled at the time the job is generated for the laser. You can see them by previewing or selecting the image and going to the Adjust Image window (Alt+I or right-click and choose ‘Adjust Image’)
Thanks. I just did what you said and while it doesn’t show in the workspace, if you do the Alt+I, you can see the changes are made. Thanks.
The image on the right has the contrast set to +25:
You’re saying that you do not see changes like this in the edit window?
I see them in the “Adjust Image” window, but not when I press the Ok button and go back to the workspace. But then when I “view” the image, it shows that the changes have been made.
And again, you changed brightness and contrast?
