Adjusting power and speed in LB on the fly
Please forgive me if I am posting this under the wrong category.
I am adjusting the speed and power settings while LB is burning under the MOVE tab. At the top of each category it shows only the percentage of speed and power. I was wondering if there is a way to know what the exact settings are? My reason is that if I tweak the settings for each I want to know what values so I can recreate the values again under the cut/layers tab and save them for that particular project.
thanks much!
I don’t really understand. If your speed was 100 and you click on +10%, your speed will be 110. It should be an easy calculation?
Maybe that’s more part of the problem. You should do a material test before and not need to adjust settings during the runtime. I only use that function once in a few months if settings had been off accidentially.
And be aware that you can’t control them independently and that there is a limit of the rate change.
