During the burning process, you can adjust speed and power.
Is it possible to set these so that they can be adjusted individually instead of affecting each other?
If so, where to do it?
Adjustments with this panel during burning
look for the picture abowe
unfortunately I have the Swedish language installed
Some of the times, when I adjust one it moves the other. Just hit the reset button (in the middle) and try again.
I’ll try that, thanks.
If you want to take a screenshot, just change the language to English before, it’s just a click ![]()
No. Or better to speak, only one of them can be changed individually (I think it was the speed). The other changes both, which is not a limitation of LightBurn, but of the firmware. We discussed this some time ago, there is nothing LB can do about it.
Edit: found the post: Question regarding power and speed adjustment on the fly - #3 by ehendrix
