Adjusting the size of a line of text without effecting another line of text
Hello: If I have 2 lines of text how do I adjust the size of one line of text without effecting the other line of text? For example I would like to emphasize the first line of text by making it larger but then keeping the second line of text smaller.
At this time, that is not possible in LightBurn. You would need to make two separate text blocks.
This applies to all other text modifications as well. Changes such as bold, italics, font size, distortion, or any other settings changed in the Text Options Toolbar require the affected text to be placed in a separate text box to isolate those changes.
What is a ‘separate text box’?
I’ve noticed that any text, even when separated by a carriage return, is grouped.
If I move to another point on the screen & enter text it isn’t grouped. Is this behaviour documented?
A separate text box would be as you stated, going to another area on the screen, and starting typing new text in a separate area. Then that area can be controlled separately from any other text, ie made bold, size changed, etc.
thank you!
