are there any affordable (used) C02 lasers on the market for <2000€?
It should be able to engrave with 600 dpi and should have some basic features like air assist, autofocus would be also very nice.
The device would be needed for high resolution engraving only.
To produce a 600 dpi image, you laser/material needs to be able to produce a ‘dot’ that is 0.04mm.
I don’t have problems with the 0.1mm dot (254 dpi), but I don’t think I can produce a dot less than half that size. I don’t know if it will focus that small.
It’s also dependent on the material you are using. Slate won’t make as nice a ‘dot’ as acrylic.
Might get a smaller ‘dot’ from an led or other type of laser.
My China Blue is 50 watts (advertised), purchased through OMTech, it was right at $2,000.
Thanks for your answer.
I want to engrave photos on wood. At the moment i’m doing this at 300 DPI and the results are already nice. But then i see Lasers like the glowforge where they saying you can engrave with >1000 DPI. Is this practically possible?
I know that you are limitied through the resolution from the source image and that the DPI changes when you scale the picture but i think most of “normal” photos that were taken the last years are in the range of 300-600 DPI when you want to engrave them on 150x100mm for example.
As @jkwilborn writes, for 2000 euros you get a new machine, if you buy a used one, you still have to buy a new tube
Your desire for this resolution is unrealistic for a CO2 laser.
