Everything has been working great, but I had a cam and had a moment, so I set the cam up and everything looked great but then I started to engrave, and I have a big issue. If I have a circle to engrave it is oblong does anyone have any idea what is wrong? I have uninstalled Lightburn I have even tried older versions, I have updated all firmware, I have gone through the cam setup again, updated windows. did type $RST=*, deleted prefs folder everything I can think of.
Hi Chris
Either a belt got loose or something is a bit wrong with your hardware
Try running this on a bit of scrap wood and post results please.
Dot Test with Angle.lbrn (46.3 KB)
Creality are not easy to correct, but you need to tighten both X and Y belts
Surprised you had not gotten any issue before.
