As the title suggests, After rehoming my laser engraver, it perfectly rehomes at 0,0 but then moves to -360 according to the move tabs “get position” button. Another keynote is that on lightburns display my test design will be on the top left but the laser will move to frame the part on the bottom left. This makes me think the Y value is flipped but is still being read correctly by light burn but not by the machine itself?
Info about the Laser Engraver -
Wainlux JL3
According to lightburn’s console, it is running VER:1.1f.20180715 .
The machine does have limit switches. Lightburn is set to absolute coords. Not quite sure what other info I can include?
I tried reading the setup document in the docs section but got a bit confused and didn’t want to mess with it too much. What should I do?
After testing the laser, I have also discovered the image was flipped on its x axis. Being mirrored when engraving compared to what it looks like on my screen
The machine homes to the top right.
Bottom left Corner - x=0, y=-360
Bottom Right Corner - x=370, y=-360
Top Right Corner - x=370, y=0. Note in order to do this I had to put y=360 and then hit go on the move to position section.
Top Left Corner - x=0, y=0. Still have to have y=360 in order to have it go to what lightburn indicates as y=0.
Here are the screenshots of what pops up when I run the commands you mentioned.
The coordinates that you indicated for the 4 corners validated that the expected origin position was lower left. You can tell because although the actual values are off, the numbers decrease as you move left and down.
The G92 is meant to reset the offset that you see in:
[G92:0.000,-360.000,0.000]
However, recent experience leads me to believe that this may not have addressed the issue without proper setup or by itself.
So it is printing in the correct location relative to where it is on my computer screen. The images are no longer printing mirrored. So it seemed to have fixed it. Although I still find it strange that it rehomes at the top left but then moves all the way down to the bottom left as its resting position. Not a big issue for me and I can live with it.
