After updating lightburn Using same materials as before and same settings laser won’t engrave in lightburn but works in xtool creations just fine. I’m so lost…[quote=“Derek7810, post:1, topic:134020, full:true”]
Make sure the units you’re using are indeed what you expect. Typically for diode machines you want to be using mm/min.
Ok I’ll check but I never changed that setting. Thanks
