After update 1.5.06 creality chuck rotary will not work properly
I have a Creality rotary check. After update of Lightburn 1.5.06 rotary chuck does not work properly. All images are skewed overly wide and even older files which previously ran fine do not work either all setting are correct. HELP Please
There is a chance your Rotary settings got reset
a) is your rotary ENABLED?
b) did you recheck your rotary wizard settings
yes rotary is enabled and settings for the rotary were checked and verified.
Thanks
could you post
output of
$$ in console
Also picture of your rotary wizard please?
tomorrow morning I will do as you requested and I will also run the chuck and laser from my laptop instead of my dedicated desktop for the laser. We can see if I get the same result. Not able to do it until tomorrow morning. Thanks so much!
Gil: I figured out what was wrong. I checked my laptop which had an earlier version of lightburn and went in to the rotary setup and discovered that the Three settings were entirely different, once I set them on the desk top pc to match the laptop, all was perfect. I have no idea how they got changed. Thanks for working with me on this.
Geoff
