After upgrade to 2.0.04 Focus Z and Home no longer work
After upgrading to 2.0.04 I have lost the ability to run “Focus Z” as well as “Home”. I do have Z control from the Move menu.
A coworker logging into the same laptop DOES have Focus and Home (2.0.04 running).
How can I fix this issue?
Thanks in advance
If he uses the same laser then you can use his prefs. (I assume you are using 2 instances of LB)
It’s possible the device profile being used between the two instances is different (for whichever reason)
On the device profile that is working (your coworkers) - go to ‘File > Bundles > Export Bundle’ and export a device bundle including the device profiles. Then, open that bundle on your own instance of LightBurn.
You saved the day!
Perfect fix!
