Is there a air assist kit that I can buy for everything I need when it comes to having air assist help?
What type of laser will you be fitting it to?
Hi, i made my own with https://www.amazon.co.uk/gp/product/B007WSLGN8/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
and 4mm silicone tubing and copper brake pipe 3mm and 2 mm all from Amazon.
Only needed about 2 inch of the 2mm and about 8 inch of the 3mm.
Guess the rest will come in handy if i ever need it
Plus a few cable ties.
Same laser…
There is at least one kit made by a company called CloudRay…
It has all the bits needed plus some you may not need or be in a position to use, but, it will give you a really good idea of what’s needed.
Here’s a very good YouTube that shows it all.
Also this little pump will work but if you have an option for something a little bigger will be super.
He has a diode setup.
Ah OK, then really I can’t help much
The actual setup is really nice and you can make an air for cutting, no air or little air for Engraving setup, or, just no air
Well one hidden trick for cutting is use nitrogen instead of air. Elimination of the O2 will reduce the char and browning of your edges.
