at the output of the card I have 3v which means that the relay is in operation, the voltage at the output of the card must be
0 v for the relay to change position. But no command changes the board voltage
Those are valid GRBL g-code so āOkā is a fine response. The question then is what the controller does with the commands. Meaning does the hardware properly react to the command and expose a voltage shift. Did you measure this.
Note that LightBurn is already generating M8 and M9 commands in its g-code so you would not need to enter this in start/stop. Also, in the previously linked Topic they mention using M7 instead of M8 to enable air assist.
I have no change in the card with these commands the voltage is always 3v, maybe the firmware does not allow it.
Still no response from the manufacturer.
Iād suggest measuring voltage for all the unknown pins on the board both during rest and with M7 and M8 enabled. Itās possible that itās getting exposed elsewhere.
the SCL output must not work with the M7, M8 or M9 commands. I donāt know how the firmware was coded. I donāt know how to find what it works with, if it works other than always on (+3v)
Iām suggesting to test the other pins. Itās possible that M7 or M8 is affecting voltage on another pin thatās not currently apparent.
Iād suggest probing the other pins on the I2C port and then the runback button and touch screen interface ports.
Iāve been following along⦠but I question the wiringā¦
This is a photo of my MKS DCS32 controller⦠the label is very clear to as to whatās there.
I would think the green wire would connect to SCL. Wouldnāt that be the one on the bottom?
Even the one in the link he posted is wired that wayā¦
I think he has the relay wired to the i2c ground connection⦠configured like this the relay should be inactiveā¦
I would check on the wisdom of using the SCL output to directly drive a relay or in this case an optical isolation device⦠I donāt know and the data sheet isnāt likely to mention it, since the specifications keep the current low.
Here is the schematic of mine⦠looks like itās just i/o 4 No idea of how much current they will sink⦠maybe there is a buffer in between?
They also do not supply current, they pull the line low when active.
you canāt see it well on my photo but I put the wire to the bottom terminal, the connection is well done as in the picture
tomorrow I will take measurements on the other connectors
jk wilborn is that on your motherboard when it is just powered, you have a voltage of 3v between scl and gnd?
Mine is still in the box, havenāt put it into a machine yetā¦
Measuring the open collector output of an i2c device isnāt going to do much, as by design they only pull the signal low⦠Iām guessing that itās just floating thereā¦
If I get a few Iāll hook it up and see what it will do on itās ownā¦
I did power mine up and it reads 0 volts from ground to the SLC pin. I have the standard cnc firmware in it, not for a laserā¦
Take that back I loaded a newer version and I get a lot of initial information, but canāt ask it anythingā¦
Ok thank you, at rest 0V, which I find logical, me on my card I have 3v.
I will do research on the other terminals otherwise I will change the motherboard.
It sounds like the output is on, maybe itās not hardwareā¦?
What firmware is loaded?
I donāt know what firmware is on the motherboard. Is there a way to find out?
When you plug it in and it connects, it should display itās firmware on the console in lightburnā¦
ok iām looking at this
twotrees just replied to me: Dear,
the firmware of TTS mainboard doesnāt support using M7,M9 command,but DLC 32 mainboard could do it(its publish firmware could support it)
Regards
I then asked if he could change the firmware.
This afternoon I will look at the firmware version, I wondered if it would support the firmware of a DLC32.
DLC32 uses GRBL_ESP32 for its firmware.
While the LTS and DLC32 boards are similar it looks like theyāre not quite electronically the same. You can see some dialogue about this in FluidNC discussion (FluidNC is the successor to GRBL_ESP32):
Feature: Configuration for MKS LTS 1.1 Ā· Issue #857 Ā· bdring/FluidNC Ā· GitHub
Itās not clear from the thread if everything ends up getting working but it looks like it have.
