Does anyone know where you can purchase air assist tubing? I think it’s latex rubber. I’m looking to get the same type of tubing that comes with air assist pumps - that is very soft & flexible,. I tried to purchase fish tank pump tubing - but it’s just too stiff.
Amazon, automaton direct,mcmaster carr.
You want silicone tubing, perhaps in ¼ inch = 6 mm ID:
https://www.amazon.com/Metaland-Silicone-Tubing-Brewing-Winemaking/dp/B08L1TZ54J
That’s PVC and, as you found, is basically useless.
I used some black stuff that is pretty tough, same that Sadler uses. Don’t know exactly how your head is configured…
I’ve run 1650mm/s and it holds up well, no silicon I’ve seen would really work for mine… I’ve run this over a couple of years now… no failures. Mine is drug around, as I have no drag chain on the head.
You can see how it’s used here…
Good luck
