I’m going to add Air Assist to my Ortur Laser Master 2 Pro with a nozzle that fits the lens barrel and shoots straight down. I have a Paasche Air Brush Compressor that puts out 14 liters/min and a regulator that puts out a maximum of 30psi. Will this work?
That should be fine for an Ortur as it’s 840 Liters per hour. If you already have it, start with that and if it’s not enough then upgrade. But I feel like that’s more than enough.
Thanks for the quick answer. I’ll give it a try.
You will likely need to adjust it for engraving vs cutting. Make sure your pieces are held down well or they’ll blow off with that much power I’d think.
