Air-Purifier Recommendation
I have a Creality Falcon 2 Pro, and i’m looking to buy a air-purifier, and it doesn’t have to be the recommended creality falcon 2 version, can anyone please recommend one that will cope with engraving and cutting.
Thank you
I can highly recommend a FumeClear fume extractor. I own the FC-350 and it works fantastic, they are pricy and worth the money.
Air purifiers are nice, especially for neighbors, but any of these need to be vented to the outside. None of these removes potentially toxic gasses from the debris left by the laser, so you want it out of the room work area, outside.
:grinning_cat:
I vented 2 machines outdoors, through board in window. Little info on life of expensive filters. Can you second-source filters? My iCube has charcoal filter, started smelling smoke after about 4-5 uses. Now I sit it on top of the SF-A9 machine with a board and use vent to outdoors.
If my duct fans go out, I might consider using cheap leaf blowers. :joy:
