Ajustes de maquina
Hola tengo la ultima actualizacion 1.7.08 queria usar el eje rotativo, pero no me aparece los ajustes de maquina, mi laser esta conectada a la computadora y la reconoce pero no aparece esta opcion en editar, que puedo hacer
Are you following any instructions provided by your laser manufacturer? if so, are you able to share them?
Here’s our documentation on how to set up your laser using a rotary attachment:
You should try using the rotary setup window before adjusting any machine settings. To find it, go to Laser Tools>Rotary Setup
Make sure you do not have Beginner Mode selected.
