Hi Good Day, I’m using Algolaser DIY Kit 5w. My Laser is working fine but not Homing, if i click Frame, it Fire but the laser not moving and it like it’s locked. Maybe someone can help me, And From the Console it says Alarm 1
Sounds like a limit switch is constantly triggered. Check them mechanically and all the connections.
What should i do?? It’s my First time using Laser Machine
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
This was keep showing in console
There is a device profile on this page that you can import when you create a device profile for your laser in LightBurn: Support | Algolaser
Using the .lbdev file from that page will ensure that your settings are correct for your machine type.
Your manual references a limit switch on page 16, but there should be two. You should double check that they are both wired to your controller correctly.
Here’s our documentation on errors and alarms for your reference too!
Thanks for this. I’ll reply on this thread once fixed
