Alarm 2! After wrong position X,Y...Then it´s impossible to conect the laser with right click in "Devices"
Hi Guys!!
I ´ve a problem to reconect my laser Sculpfun S30 PRO after an alarm 2. For example, I turn on my laser and the lightburn and laser makes homing perfect, then we click in movement to try to test movements and pe I try to move out the range working, alarm 2 appears of course ans says" Alarm 2: G-code motion target exceeds machine…(right-click the “Devices” button to reset… Then I do it but my laser doesn´t move mora and inthe console appears “Waiting conexion” all the time. The only solution that I ´ve found it´s Turn off the laser and turn on again.
Please ¿Anyone knows other way to reconect the machine?
Thanks In Advance
This is likely relevant:
I think that’s the correct behavior. Once a laser goes into a severe alarm state, you have to reset the controller with a power cycle. The software can’t reset. So, as PY suggested, make sure you never run into a situation where such a severe error occurs.
Ok, Thank you for your support!!!
