Alarm 2 Help - G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the 'Devices' button to reset the connection)
Hi my lightburn keeps bringing up the following alarm. It is homing correctly and I have already done a reset.
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Screen shot of device settings below.
Have you read the Troubleshooting’ guide in the Doc’s ?
I see you are running the job in Current position, the guide may well help
What does the preview window show?
It is hard to see from your screenshot, but do you have anything outside of your grid/ workspace? If you click on the laser preview window, what does it show?
I also noticed tat you have the laser set up to auto home on start, but it starts running at current location instead of absolute coordinates. Maybe that is a problem.
