Alarm 2 in lightburn monport k40
yesterday I started getting this alarm. I have tried changing settings in the book and still nothing. I cleared everything I know to clear, reinstalled lightburn and it still pops up. It will home and that is it. Hopefully i am just a dumb new user and its something i missed.
I have a monport k40
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Stream completed in 0:00
[MSG:Reset to continue]
ok
MonPort
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
What “Start from” are you using
Absoluet coordintes?
can you post a full screenshot of your lightburn?
is this what you need? I have tried all the origins and it seems to make no difference
ALARM:2
On or near line 0:
ok
MonPort
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=2
$24=500.000
$25=1000.000
$26=250
$27=2.000
$30=1000
$31=0
$32=1
$33=1
$34=1
$35=0
$36=0
$37=1
$39=0
$100=160.000
$101=160.000
$102=800.000
$110=8000.000
$111=8000.000
$112=100.000
$120=600.000
$121=600.000
$122=20.000
$130=300.000
$131=200.000
$132=197.000
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,253|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
ALARM:2
On or near line 0:
ok
MonPort
ok
You must be in current position or used defined Start From
Change to absolute coordinates
post a Screenshot image of your lightburn
Change here to Absolute coordintes
Follow up read that is important:
It still throws the alarm 2 when i try to frame or burn
Your image does not show any selection in the workspace. Can you upload the Lightburn file?
it hasn’t made any difference what project i try it throw same alarm
Let me try again…
Homing
ok
sys.aborts
JY230 INIT SUCCESS
MonPort
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=2
$24=1500.000
$25=3000.000
$26=250
$27=5.000
$30=1000
$31=0
$32=1
$33=1
$34=1
$35=0
$36=0
$37=1
$39=0
$100=160.000
$101=160.000
$102=800.000
$110=8000.000
$111=8000.000
$112=100.000
$120=600.000
$121=600.000
$122=20.000
$130=300.000
$131=200.000
$132=197.000
ok
I meant the .lbrn2 file with a project that fails in it. Your last post is the GRBL parameters.
I dont know what you are looking for. every project fail now. It will not come off home for anything.
That is a different kind of problem. I was looking for the possibility of your part being at the edge of your workspace and overscan causing a problem.
It now sounds like you have a coordinate setting issue. If Home works, motion control is still working.
Enter these one at a time in the Console window. We already have $$:
$I
$G
Now copy-paste the output in the Console window in your reply.
When a Forum member asks for you to do something, you should not worry about why unless they are asking for personal or proprietary info. If the reason does not become apparent by the time of the solution, they will explain their reasoning. We are here only to help, not judge. This is the most civil, and supportive, Forum I have ever seen, which is why I continue to participate.
By the way, welcome to the forum. You will learn a LOT here!
Waiting for connection…
Project loaded in 4 milliseconds
ok
[VER:1.1f.20230606:]
[OPT:VZHL,35,254]
Target buffer size found
ok
Homing
ok
sys.aborts
JY230 INIT SUCCESS
MonPort
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P|Ov:100,100,100|A:S>
ok
Starting stream
ALARM:2
On or near line 0:
ok
MonPort
ok
ok
ok
Starting stream
ALARM:2
On or near line 0:
ok
MonPort
ok
MonPort
MonPort
MonPort
MonPort
MonPort
MonPort
MonPort
MonPort
MonPort
Starting stream
Layer C03 Pass 1 of 15
Layer C03 Pass 2 of 15
ALARM:2
On or near line 0:
Job halted
ok
MonPort
ok
ok
sys.aborts
JY230 INIT SUCCESS
MonPort
$I
[OPT:VZHL,35,254]
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
$G
[GC:G0 G54 G17 G21 G90 G94 M5 M M9 T0 F0 S0]
ok
ok
This shows your project completed at least 1 pass. Is this what you saw?
Something like this sometimes indicates a communications issue, like a bad USB cable. Bad communications can give you a whole batch of misleading symptoms, often appearing random. Do you have another USB cable you can swap in?
I was looking for the possibility of a workspace offset causing your problem.
have swapped the cable and still same. it homes and does nothing else. I think I either have a bad board or something in software is corrupt. I attempted using it with a different computer but I think it read the info off card and gave me the same alarm 2 code.It did not complete any passes I do appreciate your helping
have you done what i said and done it in absolute coordenates?
Next picture you sent was still in user origin
